Old 07-02-2009, 01:10 AM   #10 (permalink)
MissileStick
Could you close the central heating vents to the rooms you're not living in?
Also, it sounds like your space heater doesn't have a thermostat, but just a heat setting. A thermostat (by definition) is a device that turns on and off to maintain a given temperature. Would it be possible to get a space heater with a built-in thermostat? It sounds like that would solve your problems.
