Old 07-02-2009, 02:48 PM   #6 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
Originally Posted by PaleMelanesian View Post
How did you get it for $124?
Actually it was $127.XX they have/had a 20% off and free shipping coupon for JCWhitney.com online orders, just lookup JC Whitney 20% off coupon and you should eventually find the coupon code.
I figured out the Jetta, I finally took the diesel on the highway and it says I am getting 27mpg which means the Scanguage is WAAY off, I had it set for Diesel A, Diesel B ended up worse accuracy wise (not to mention the throttle doesn't go up like diesel b anyway). The funny part is I can sustain around 46mpg per the scanguage in town at lower speeds but at highway speeds its always around 27mpg which is very very wrong.
Not sure how I correct/tweak very very inaccurate readings with the Scanguage on my Volkswagon Diesel.
The Buick was quite accurate out of the box, Dodge was very close but apparently the SG doesn't like diesels much.
Sad part is if I do a lot of tweaking I will need a way to reset the SG often as I move it from vehicle to vehicle often; as the other drivers won't use or look at it.
Cheers
Ryan
