Old 07-03-2009, 04:44 PM   #7 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Whuups !
I meant "blow-by ".
The spark plug has a large amount of oil on the threads when I remove it, yet the spark plug wire boot is spotless. ( Also the tubes are clean on the sides .)
I don't understand where that the oil is coming from.
Also, I don't understand how that oil could seep into the threads like that, unless it leaks downwards as remove the plug. ( The plug is screwed in very tightly.)
This sounds like the ring seal problem that you were describing.
My car is very sluggish, yet the F.E. seems normal ( around 38 MPG, with over 45 MPG on the highway on a nice long trip. This is with an automatic. )
I have been thinking that if something was wrong with the car, that the mileage would drop. I guess this is not the case.
Also, I might add that I passed my emissions test easily. If oil is getting mixed into the engine where it shouldn't be, wouldn't this cause more pollution ?
Thanks !
