Old 07-03-2009, 09:00 PM   #283 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
well, if hydrogen fuel enrichment is only good for cutting idle fuel consumption in half (source), I have a much simpler and infinitely more effective solution. Turn off your dang engine INSTEAD of idling.
lean burn does help, but it is not the ultimate solution, it is a band-aid for an over sized engine. bsfc naturally peaks around stoich because you aren't passing unburnt fuel (rich) or pumping unused air (lean).
