Old 07-06-2009, 07:38 PM   #11 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I think you may have quoted the CCA or the cold cranking amps not the AH of your battery. 55AH is possible for a starting battery but 550AH is in the range of industrial storage batteries.
Assuming your alternator is working properly and a 55AH battery, (think 55amps for one hour in ideal circumstances) an approximate guess would be less than an hour but more than 1/2 hour. That's one hell of a coast.
Now, If you are coasting a lot you may end up with a charge deficit which means that your battery is not fully recharging after many coast/start cycles. this will shorten the life of your battery from the hardening of sulfate crystals still on the plates due to incomplete charging. (they have not gone into solution) This will hurt your FE because your alternator is working overtime to charge your battery but it may never take the charge.
The solution to this is to hook up a battery charger to it when you get home. Some people have a solar trickle charger to keep their batteries topped up.
Most new car warrantee issues are battery problems for just this reason.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
