Old 07-07-2009, 07:59 AM   #29 (permalink)
Shawn D.
Harebrained Idea Skeptic
The White Car - '84 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 535i
Last 3: 23.86 mpg (US)
Stock Apples vs. Prototype Oranges
Originally Posted by theunchosen View Post
I disagree on the AFR. Honda, Toyota, Ford, GM and others have all built mule engines that can do better than 35:1. Not only that they can do it without suffering diminishing returns.
There's a tremendous difference between building unique/one-off/prototype/mule engines for research and attempting to replicate the results on an engine with stock architecture. Unless you are completely redesigning and fabricating new pistons, chambers, valve location/angles, injector location, spark plug location, etc., you cannot make such a comparison. Adding heat sinks to pistons doesn't count as an architecture change.
BTW, why is this in "Success Stories" when the main result so far is an engine meltdown?
Last edited by Shawn D.; 07-07-2009 at 08:03 AM.. Reason: Wondered why this was in "Success Stories"... ;)
