Old 07-07-2009, 10:43 PM   #16 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Originally Posted by PaleMelanesian View Post
I typically run 80-85 LOD in my manual. It's hard to get that in an automatic. Instead, I aim for high-ish load (maybe 60) while still keeping it at about 1800 rpm, but especially below 2000. With the auto, I let the rpm dictate things more than the LOD.
Once it locks up in top gear, it's more like a manual. 90-95 LOD is where it unlocks, so I can push it right up to that limit. (at least in my Ody)
This is good advice -- I'll have to keep an eye on the TC unlock vs. LOD. The throttle-shift cable is a bit tighter, so the LOD might be a bit lower. I'll try it tomorrow
I call it "coaxing an upshift". Or sometimes, "@!#!$# why won't you shift already?!"
I get there often too -- especially with the darn "Hill Logic Control". D3 overrides the 2-3 shift logic, but 4th is completely up to the computer.
In normal driving, I just lift, it shifts, and give it the gas. Sometimes the process is too quick and it engages a bit hard on the next gear up.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
