Old 07-08-2009, 03:03 AM   #4 (permalink)
Frank Lee
Blue - '93 Tempo
F150 - '94 F150 XLT
90 day: 17.21 mpg (US)
Sport Coupe - '92 Tempo GL
I haven't ridden it yet. Near as I can tell the bike weighs 95 lbs w/o battery pack (very awkward to use a digi bathroom scale for this...) so 147.5 lbs total.
Looks like maybe it isn't going to be a smooth plug-n-play operation. Batt pack decal SAYS 60v; it's been on the charger 24 hours and the red/green LED never went solid green, and it's only up to 35v, sooo.... might have a problem? Cracked open the battery box (52.5 lbs) and found (5) 6-DZM-12 batteries.
There are no glaring physical defects and the batt cables are very firmly attached so I'm not inclined to disturb them just yet to check the batteries individually (well OK. I did try to get one cable off and it didn't come easily so for once I decided to stop before breakage occurred ). Was just going to throw the charger on it longer but now think I may have already overcharged. The thing to do is simply put the pack on the bike and see what it does I guess.
It does have functioning pedals, although I'm sure this thing would be a total slug compared to pedalling a normal bike. It's way too small for this big galloot to get proper pedalling ergos- and there's the little matter of the extra 114 lbs vs my trusty old Fuji- but just sitting there passively riding should be just fine. My guess is the pedals are mainly useful as a range extender- use 'em to help on accel and up hills and the battery pack thanks you very much and rewards you with much longer range.
