Old 07-08-2009, 03:34 PM   #10 (permalink)
theycallmeebryan
2003 Ninja EX250 - '03 Ninja EX250
90 day: 87.63 mpg (US)
Saturn - '99 SL1 Base
The cheapest way people go about water injection is using the stock windshield washer reservior and pump hooked up to a hobs switch or contacter. This application only works for WOT or Boosted applications, and wouldnt really work for non boosted applications. This is because there is only 1 level of flow which you'd only be able to use at WOT.
For N/A applications, you need to have a map sensor tied to a controller to manipulate the voltage going to the pump.... so that its not 100% at 25% throttle position, for example.
Technically, you may be able to get by tapping off the throttle position sensor if your car has one. Or, just hook a potentiometer up to the carb and do it that way. Or perhaps use an electrical vacuum gauges and alter flow that way?
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
