Old 07-08-2009, 06:07 PM   #46 (permalink)
tasdrouille
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Well, there's some oil in wd-40, so it will contaminate your pads. The question is if the contamination is significant or not. You could spray brake cleaner before use after storage. Worst case scenario is that you take out your pads and broil them in the oven for 30 minutes when there's too much contamination, it apparently helps "burn" the oil out.
www.HyperKilometreur.com - Quand chaque goutte compte...
