Old 07-08-2009, 06:24 PM   #11 (permalink)
CobraBall
CobraBall's Avatar
Try a bottle of RXP. RxP Main Menu Tune up your engine with RxP Gas Kicker. RxP removes carbon build-up from your engine. This restores lost power, improves fuel economy and significantly reduces emissions. If you want your engine to run like it did when it was new, add
Photos Piston before and after WELCOME TO RXP PRODUCTS, INC. THE HOME OF THE LITTLE RED BOTTLE
The science behind it. This IR radiation is absorbed by the filter that RxP provides to the fuel mixture and this mixture is preheated prior to combustion. Thus the temperature of the combusted gas is obviously higher, but also the chain reaction (combustion) is promoted s
It can/does overcome the crappy federally mandated gasoline/corn brew.
