Old 07-08-2009, 10:23 PM   #3 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
So, you added it to your gas? Or you used it to remove the adhesive left behind by the badges?
I've added Acetone, Xylene, Toluene, Methyl Ethyl Ketone, and several other "bad" things to my engine before, because they were free and I knew I'd need gas before I could afford it again... none of them did anything to my MPGs, at least that I could ever tell from tank to tank measurements...
The Acetone may have (possibly) damaged a seal or something in your fuel system, so you may be leaking slight amounts of fuel, not enough to really know it.
