Old 07-11-2009, 03:04 PM   #1980 (permalink)
TheSGC
Originally Posted by MPaulHolmes View Post
I believe the flip-flop isn't resetting OR it's related to the undervoltage lockout.
My next test will be to remove R14, and put in a LARGER resistor, thus lowering the overcurrent trip point. Then I'll take a drive, and if it trips almost right away, I'll know the overcurrent shutdown is coming on, and not getting turned back off.
Maybe I am reading the wrong code, but in the Wiki the code I looked at doesn't seem to run the Reset Current command, it appears to just stop after going into hardware current limit and setting pwmDuty to 0. Which code are you using?
1996 Civic LX EV
