Originally Posted by RobertSmalls
The reason nobody's done it at home is twofold. One, the stock engine is pretty darned efficient, and there's little room for improvemnt in CO2/mi or even gal/mi with a diesel. Two, there aren't a lot of cheap Prii with dead engines, because the stock engine tends to outlast the car.
I can't support this claim at all.
Diesels are typically ~30% more efficient (fuel used per mile) than gasoline engines, right?
So how is there "not much to gain" from using a diesel with the same hybrid system?
I don't remember seeing a suggestion to take out the hybrid setup, just to use a diesel engine instead of gasoline... that would make the Prius ~30% more efficient on diesel.
EPA rating for the Prius Gasoline Hybrid is: 50C/49H
30% higher than 50mippigs is 65 mippigs... I'd rather have the latter, and that's the "we're not really going to try" EPA estimate.
