Old 07-12-2009, 01:26 PM   #1 (permalink)
vtecn8ive
Civic Vx engine question. stock exhaust manifold vs. stock exhaust manifold
I'm curious if the d15z1 (civic vx) engine will run properly if you use a regular obdo exhaust manifold and down pipe.
The d15z1 has the o2 (5-wire) sensor on top of the manifold (think of hf manifold) and its right before the catalytic converter.
The d16a6 (one of the stock obdo exhaust manifold) is a header type 4-1 style and the catalytic converter is after the down pipe.
On my Civic rt4wd I need to clear the transfer case and so I either need to modify the d15z1 down pipe or I can run the d16a6 without modifying it and just stick the 5-wire sensor in there.
Any suggestions?
Thanks,
Shane
