Most if not all electrically controlled transmissions have a built in protection feature that will not allow it to shift into a certain gear. Also they have a delay when actually shifting to the gear of ~1 second +/-. This is to protect the tranny from serious damage but this is not say that you can not do serious damage to it if you try hard enough. In your case I bellieve you are ok.
