Old 07-14-2009, 12:30 AM   #3 (permalink)
LUVMY02CREW
LUVMY02CREW's Avatar
TANK the fifth - '02 S10 Crew Cab 4x4 LS
90 day: 20.13 mpg (US)
Definately sounds like the O2 sensor needs replacing. Did a Service Engine Soon light come on?
You can try to swap it with the post cat sensor to see if things improve until you can get a new one. Hopefully the new data log will show the same one not reading accurately.
FWIW, my 4.3L was acting like you are describing and once I swapped position of the sensors, the truck started running right again. The SES light was still on, but the code followed the bad sensor. Now I just gotta break down a get another one...
