Old 07-15-2009, 12:17 AM   #28 (permalink)
NeilBlanchard
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
Someone already mentioned it, but it is critical to have your tires pumped up -- try 38-44psi if your tires have 44psi as the sidewall max.
Also, your tires can tell you if you have an alignment problem -- are they worn evenly?
If you are sitting at traffic lights, and you can see the lights in the other direction -- shut your car off while you are sitting, and start it when you see the yellow in the other direction (or when you see the brake lights go off a few cars ahead of you). Or, at least put it in neutral while you sit.
The trick with ecodriving is to only accelerate up just enough to let you coast to the next stop -- have you tried coasting in neutral? If you need to slow down, downshift to 3 or 2 and let the engine do what it can to slow you down, and use your brakes only when you have to (at the end right before you stop). Think of it as a challenge to keep your brakes cold!
