Old 07-15-2009, 11:06 AM   #9 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by TheSGC View Post
About battery prices, 24 Optima's is about $5.1K and the same amount of lithium to get the same power as those Optima's is about$ 5.9K, so why even go with lead? You get about Half the useful power from lead acid batteries, and with lithium you get most of the power. So, in theory, 144v 120 Ah LiFePO4 is better than 144v 200 ah lead sled, due to the difference in Puekert's Effect and the difference in weight.
What are you looking at for 120Ah LiFePO4 batteries? Thinder sky's go 40, 60, 90, 100, 150, 160...
I would probably use the 160's. In the spec sheet there rated to 3C so thats 480A continuous, and 1600A peak. I dont think the high current pulls in the 1000A range would cause much damage to them.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
