If you make it 3 pieces, use a piece of wood internally on the corner to attach the pieces together. The wood may need to be contoured to accomadate your shape.
If an angular bend is desires, you can remove both inner skin & ribs out of the desired area. I would probably heat the outer skin also. You may want to support the bend with some bent sheet metal as well.
Practice first.
Don
