Plenty in stock, designed to work with 14+ volt vss and injector signals. There is a large resistor in series with the vss and inj signals and the pin voltage is limited in both directions by a 5v zener.
"I kicked a giant mouse in the butt! Do I have to draw you a diagram?"
