Old 07-15-2009, 06:55 PM   #6 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 39.65 mpg (US)
I bent coroplast using a propane torch and a straight edge. I clamped down the angle iron along the bend line and ran the propane torch flame along the bend line fairly quickly, with two passes. Then I immediately grabbed the plastic and bent it around the corner.
I used a steel(?) angle iron and an aluminum bar for straight edges. The bend is very strong.
You could also use separate parts and zip tie them together.
Nissan Versa Aeromods
