Old 07-15-2009, 06:58 PM   #481 (permalink)
ev59rag
Paul, another question? sorry for too many. I test drove my car last night, well it did not work....
Did you use your ignition key to turn on your contactor?
if yes where did you connect it? what line did you use. I tried the wire from starter but did not work. Checked how much amps the contactor is drawing... not much, just 1.5 amps.... Check if there is power, yes there is power. Hmmm where else can I hook this up?
If not? then did you just add a manual toggle switch to just turn it on and off?
Thanks.
EV59rag
Parting out my EV.
ES-31C D&D Motor
Alltrax 7245 Controller
Paul & Sabrina's Controller (never used)
