Old 07-16-2009, 11:37 PM   #5 (permalink)
Old Tele man
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...the "new" Toyota 2ZR-FE 1.8L engine is Spark-Ignition Direct Injection (SIDI) which is combination of diesel-like injection directly into the cylinder but using normal spark ignition, rather than compression-ignition. One side benefit is that slightly higher compression ratio is possible (better economy and power) because (a) only AIR travels through intake manifold and past the values, and (b) fuel vaporization occures inside the cylinder and cools the charge mass.
...Toyota has an Japan-SAE paper out on development of this engine.
...GM implemented same thing on the 260 HP 2.2L turbo engines in HHR, Cobalt and Solstice.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Last edited by Old Tele man; 07-17-2009 at 01:29 PM.. Reason: corrected typo spelling
