Old 07-17-2009, 03:15 PM   #12 (permalink)
tjts1
Another good picture of my old EV1 style BMW injector top, EV6 4 hole Ford injector which replaced it bottom. You can also see the 'Ford' logo stamped on the side. Despite looking very different, this is a drop in replacement in my case.
Originally Posted by beatr911 View Post
tjts1, Wow great information! I had no idea they were so similar and swappable. Guess I should consider an EV6 type when my injectors need cleaning or replacement next.
It is posts like this that make these forums so valuble to us all. Thanks!
No prob!
This might be not everyone's idea of a good time but search the JYs. You can pull the injectors out of most cars in about 5 minutes. Note PNs, the length etc. Unless somebody else has already done the research for your particular model, ts the only way to find exactly what is compatible with your vehicle. The mazda pickup for example is just a re badged Ford ranger. It likely has bosch injectors which opens up a whole world of options. You can also clean used injectors yourself.
http://www.fordfuelinjection.com/?p=82
cheers
Justin
