Old 07-17-2009, 02:17 PM   #18 (permalink)
chipsndukes
chipsndukes's Avatar
chipsndukes - '96 Tacoma
90 day: 31.37 mpg (US)
Originally Posted by robchalmers View Post
I'd agree bump starting each time will do damage - check engine mounts too as they take a kickin.
I agree. I've been working on different techniques that don't slap the engine around as much, maybe someone can give some input...
As above riding a clutch is just bad technique. if you want to save the clutch, just straight shift without the clutch on upshifts by matching revs.
So the only way to do a high speed pulse and glide without wrecking the synchros or throwout bearing is to leave the engine on, and match engine speed when going back into top gear?
Thanks,
Chipsndukes
