Old 07-17-2009, 03:37 PM   #46 (permalink)
NiHaoMike
Originally Posted by Clev View Post
Use a cut-off valve for the shower like this one:
Shower cut off valve - Save Water - Be Green | greatgreengadgets.com
That way, you're not wasting your precious hot water by having it run down the drain while you're soaping up, and you won't also have to fiddle with the water to get the right temperature when you turn it back on.
If your water heater is tripping the dryer, you've definitely got a problem.
It's actually a little cheaper to make one out of a ball valve and a close nipple. (IIRC, shower fittings are 1/2" thread.) Both of those are available at Home Depot for about $6 total.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
