Well, the eclipse has a bosal header and exhaust, no catalytic converter, has a short ram aluminum intake, and 21lb/hr injectors, 60mm throttle body and 2.5" intake ducting (I've really got to change that..). I've also ported the intake manifold and the intake and exhaust ports. I also bored it out .020" and decked the head .0035" and degreed the engine to run with the less material on the head. The engine is running a strong 180hp at the wheels and it could be better with bigger cams and adjustable camshaft sprockets.
Still, hp/$. I've wasted money on that eclipse. I'm going for a 84-86 300zx next time around and actually have some fun.
