Old 07-17-2009, 09:20 PM   #3 (permalink)
TomEV
40 MPH - Achieved!
TomEV's Avatar
Roxy - '76 Citicar
90 day: 125.95 mpg (US)
The single bearing was a common way to support the armature in some golf carts. Fortunately, a new motor can be had (if the old one isn't repairable for a reasonable price) for about $350 - $400. There are various on-line sources - some quite a bit higher than others.
If you look up EZ-go, you should be able to find a few. Before ordering, make sure you take measurements of the motor shaft (diameter, spline count, length) and tell the store it is for a Spicer/Dana rear end. Will save some headache in shipping it back if some measurement is not correct.
There are two reasons I can think of that may be an issue - overspeeding and a loose field shoe.
