Old 07-17-2009, 10:08 PM   #39 (permalink)
Mecrez
Car - '06 GTO
truck 2 - '99 S10
Kudos to the OP for trying someting different. I realize my suggestions are unrequested and unqualified, but there are things that can be done to make this work better.
I get the impression that christ is being sarcastic, Basslover I would recommend that you look into ECR (Exhasut Gas Recirculation) there are limits before you get to unstable combustion
Typically when an engine is run lean, more ignition advance will help, higher power ignition such as a CDI system will help too.
There is a limit when a cylinder will not have enough fuel to "fire", but a good strong spark may help that.
keep at it and report back with what does and doesn't work.
