Thread
Suzuki Burgman modification (aerodynamics + gearing mods)
07-18-2009, 05:05 PM
75
permalink
janvos39
FKB
- '03 Focus DAW/FFDA1/5PFDMW
90 day:
45.7
mpg (US)
I had a problem with the overdrive in my gearbox. The shifting pin broke when shifting down. Since this shifting has to happen without the help of a clutch it is a very delicate moment. Normally i drop the speed to 25 mph before shifting down from the overdrive gear to the first gear. Only once I did this at a higher speed with the broken pin as result. So I had to go back to the standard Suzuki gearbox. And immedately the MPG dropped.
The plan is now to work with a stronger shifting pin including a support ring and to add an overrunning clutch in the wheel drive shaft. So shifting down will be done without the bike driving the gearbox.
This will also allow me to run idle when throttle is closed and do some coasting or when I have a larger battery installed do EOC.
08:42 AM
janvos39
View Public Profile
Send a private message to janvos39
Find More Posts by janvos39
