Old 07-19-2009, 04:53 PM   #3 (permalink)
tasdrouille
Moderator
tasdrouille's Avatar
The Truck (Retired) - '99 A3 Jetta TDI
90 day: 62.27 mpg (US)
The Guzzler - '08 Elantra GL
90 day: 32.95 mpg (US)
The Green Machine - '00 A4 Jetta TDI
90 day: 53.56 mpg (US)
Do Rams have a MAF? I assume the gurbo is a VGT.
You should do it when cruising at low loads. Tricking the ECU into thinking boost is higher, so it's effectively dialed back. That'll will help with backpressure.
www.HyperKilometreur.com - Quand chaque goutte compte...
