Old 07-19-2009, 06:25 PM   #5 (permalink)
nubbzcummins
THE DODGE - '06 Ram 2500 ST
90 day: 22.64 mpg (US)
The Saturn - '08 Vue XR
90 day: 21.94 mpg (US)
The Odyssey Van - '011 Odyssey EX-L
90 day: 29.1 mpg (US)
Originally Posted by tasdrouille View Post
Do Rams have a MAF? I assume the gurbo is a VGT.
You should do it when cruising at low loads. Tricking the ECU into thinking boost is higher, so it's effectively dialed back. That'll will help with backpressure.
It has a MAP sensor.....The turbo is stock and pretty sure it is a VGT..... So making it think more boost is there will make it more fuel eff? How does this effect back pressure? I have 5" exhaust BTW.....Please explain your last statements as I'm
