Originally Posted by tasdrouille
Bob, where do you put your brake? BSFC maps are produced with the engine on the dyno. You work off road load. Results will obviously be different since there is a whole lot of stuff between the road and the crank, and this load is not a linear function of rpm.
I have a Graham miniscanner and it reports MG1 torque. There is a fixed ratio of 28:100 between the ICE and MG1 so I can calculate ICE torque. With ICE rpm, I have the operational power and combined with injector timing, I have everything needed. <grins>
Bob Wilson
