Old 02-27-2008, 12:47 PM   #9 (permalink)
krousdb
Ecomodding Amateur
krousdb's Avatar
Cold Fusion - '04 Prius
90 day: 67.34 mpg (US)
Update:
I met with Frank with Hybrideffects.com last Saturday. We used my car to make a mold of a lower grille block. Frank will be making me a fiberglass panel that will fit over the lower opening and hopefully I will have it installed soon. I will post pictures when I get them.
The grille block will have no openings to begin with. If I need more than the upper grille for cooling, then I will use a hole saw to cut a few openings. I will use a rubber plug to close them when I don't need the extra airflow.
I was able to get a 4x8 sheet of black coroplast. It is getting quite pricey now. The first time I bought coroplast, I paid $15. Now it is up to $30. I guess we can blame the ecomodding craze for that.
This weekend I hope to do a complete underbody pan. I also plan on working on a RH mirror delete cover panel and a windshield wiper shield.
A few weeks ago I installed new tires, ContiPremierContact in the OEM 185/65/15 size. These were highly rated by CR for low rolling resistance but they have fallen far short of my expectations. At first, my FE dropped by 10%. After 2000 miles, I still see a 5% reduction. When I put the Integrity's back on, the FE goes back up to the previous levels. When I finally do some tests to determine the effectiveness of all of these mods, I am hoping that the Conti's break in fully and get me back to where the Integrity's were. What would be really great is if I can find someone local with a Prius who could do a few highway runs so that we could do some comparisons. PM me you are willing to participate.
