Old 07-20-2009, 03:52 PM   #5 (permalink)
Old Tele man
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...looks like the unit I had on my 70½ AAR 'Cuda 340/6BBL back in 1973-74. Here's how that unit worked:
...the drive-shaft unit generated an AC-voltage that you "tweeked" (using RC filter) to create a DC-voltage that went to gauge head.
...the "in-line" fule unit was a varistor (light sensitive variable resistor) that created a resistance proportional to fuel flow.
...MPG = MILES (VOLTS) / FUEL (OHMS) = MPG (milliamperes meter movement)
...it actually worked (sorta), but only during winter months (Yuma, AZ), because vapor-lock during 115-120 degree afternoons caused totally erratic readings...so, it wasn't of much use. Good Idea, but not 100% practical.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
