Old 07-21-2009, 11:48 AM   #9 (permalink)
janvos39
janvos39's Avatar
FKB - '03 Focus DAW/FFDA1/5PFDMW
90 day: 45.7 mpg (US)
Your describtion of the problem to do hypermiling is identical for all scooters with vario drive. In the past there where scooters with 4 speed gearbox like Vespa. The only way to do EOC is in my view to build in an overrunning clutch ( see the thread manual disengage for a centrifugal clutch of Atomic). By doing that the only way to reduce speed is by braking, no engine braking possible. In a number of weeks from now I will be able to give results. Short term I have to recover from a surgery I had to undergo.
I checked the engine type on Google. With a stroke of 57.8 mm for your engine the revs your making at 60 MPH do give a piston speed of 14.4 m/s . A lower value should help to reduce engine losses, but that is not easy to make.
