Old 07-23-2009, 01:36 AM   #2066 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
I don't think the problem is lack of resolution. The problem is that it's perfectly fine (according to the throttle-power scenario) at zero rpm for the current to go to 500 if the duty is very small, since all that matters is the product of current and duty. There would be no reason in the throttle proportional to power scenario to keep one extreme from happening when the other is the opposite (huge current, tiny pwmDuty or tiny current, huge pwmDuty for tiny throttle). It wouldn't know to make current smaller, since the product would be small.
TEMPERATURE IDEA: How nonlinear are your thermistors? Maybe you could use 2 lookup tables. Make an array of maybe 63 entries (for example). One, 'R', would contain the resistances, and the other, 'T', would contain the corresponding temperatures. The 63 entries would contain the resistances for T1 through T63, where T1 would be the lowest (room temp?) and T63 would be the highest temp resistance ( for 120 degC???). T0 would be a waste since this algorithm would never reach R[0]. hehe.
Then, you could do a binary search:
i = 32;
delta = 16;
while (delta >= 1) {
if (measuredResistance < R[i]) {
i += delta;
else if (measuredResistance > R[i]) {
i -= delta;
else break;
delta >>= 1;
// Now, you know the approximate resistance, so get the corresponding temperature!
measuredTemp = T[i];
// So, you need a lookup table for the resistances, and for the temperatures
That should give you an accuracy of +/- 2 degC or so. It would be really really fast too. At most 6 if..thens.
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
