Old 07-23-2009, 04:17 AM   #5 (permalink)
electrique
Originally Posted by TomEV View Post
The single bearing was a common way to support the armature in some golf carts. Fortunately, a new motor can be had (if the old one isn't repairable for a reasonable price) for about $350 - $400. There are various on-line sources - some quite a bit higher than others.
If you look up EZ-go, you should be able to find a few. Before ordering, make sure you take measurements of the motor shaft (diameter, spline count, length) and tell the store it is for a Spicer/Dana rear end. Will save some headache in shipping it back if some measurement is not correct.
There are two reasons I can think of that may be an issue - overspeeding and a loose field shoe.
Thanks for all your help guys....I've put the motor in for repairs, I think that possible overspeed-freewheeling may have contributed to an already worn motor...
I hope to reinstall over the weekend, and will keep you posted. Tried to upload a pic of my car, but too high resolution so will reshoot pix soon...
thanks
Electrique
