Old 07-23-2009, 08:18 AM   #2068 (permalink)
JayC
2010 Prius - '010 Prius IV
90 day: 57.93 mpg (US)
You are controlling the PWM power via PI loop. But are you controlling the acceleration from one value to the next? In a pump controller I wrote, I wanted to control the acceleration smoothly. Why not add code that slews the current limited by some acceleration value.
Code:
#define RAMP_SPEED			20			// how much to increase the OCR0A value from one step to the next.
// This function runs every ms to ramp the actual PWM value from one speed to the next smoothly
		// Read the current PWM value
		TC0_READ_16_BIT_OCR0AB(temp16);			// safe inside an interrupt
		if(requested_speed < temp16)				// is the requested spped less than the current speed?
			// Our requested speed is either higher or lower than what we need
			temp16 -= RAMP_SPEED;
			TC0_WRITE_16_BIT_OCR0AB( SERVO_CLIP(temp16) );
		else if(requested_speed > temp16)
			temp16 += RAMP_SPEED;
	// ------------------------------------------------End Ramp
