Old 07-23-2009, 11:10 AM   #2072 (permalink)
dlaing
Corolla bandit - '05 Corolla CE
Does the rate of decay of the motor current depend on rpm? We could experiment, (well you could) drive a set speed, then turn off the pwm while having the current sensor infinitely loop, logging the results. Repeat for different speeds.
We know the rate of rise of the motor current does depend on rpm. If we have enough time to run 2 adc conversions while the pwm is on, then you can just compare the two.
That's a much easier experiment to run. Try always having 2 sequential current reads, and see if the decay depends on speed.
