Old 07-24-2009, 12:43 PM   #6 (permalink)
electrique
Originally Posted by Ryland View Post
Take it in to your local golf cart shop and ask or look at EV Performance mostly you need to figure out what motor it is and get a new one.
hi guys,
Your help has been invaluable....! Just got motorback from rebuild...looks great...except..I need you help again ASAP so I can get the motor installed this weekend....
There are two black wires coming out of the motor housing, that probably were attached to a sensor, which was missing when they took the motor apart? (it has been apart before judging by what they found inside)
I labelled one of the black wires as going to Blue/white as I disconnected everything before removing the motor.
I'm assuming it is a heat sensor to switch on the fan?
if so...what do i do now? Can you provide a schematic ( motor details listed in previous post) or hopefully tell me what type of sensor, where to get it locally, and where does it mount inside the motor?
I assume it is fairly generic and that I can pick one up at an autoparts or electronic shop. Can I run the fan continuously until I can find the sensor if thats what it is. Also if so, do I just connect the ends of the two wires together inside the motor to run the fan?
Hope this is enough information for you to help me.
Thanks again in advance....hope to post a pic as soon as possible...it's a green one like yours Ryland.
