Old 07-24-2009, 04:08 PM   #2094 (permalink)
jyanof
Joe
Originally Posted by MPaulHolmes View Post
It fixed the voltage problem you were having? You mean the sudden cutoff of 80 amps? or something else. the 80 amp thing has been keeping me up at night!
it fixed the problem where my voltage dropped to zero because my contactor opened before the PWM turned off and it drained the caps. Now, no matter how fast I lift off the pedal, the PWM is off before the contactor opens.
Still getting the 80 amps minimum thing... I'll take some video and post it. We should try the serial data logging too, but I'm mostly positive that I can't get below 80 amps. I tried going through the code to determine if it were possible for the throttlePos to go from 0% to 16% (80/500), but didn't get anywhere...
I'm glad it's not a problem for you - likely means it's not a controller hardware thing...
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
