LRR Viva 2 tire results
Tires Before: (All tires are 185/65/14, even the new ones)
FRONT:
Goodyear integrity (25-35psi) no tread, leak (44max psi)
Goodyear integrity (20-35psi) no tread, rapid leak (44max psi)
REAR:
Radial classic (35psi) no tread
Radial LTE Futura 2000 (35psi) no tread (44max psi)
Tires NOW:
FRONT:
Goodyear Viva 2 (44psi) ~LRR
REAR:
*Rear is same as before*
***And now these are my last 3 results (I'm only showing the last 3 because they are with the same weather, And I removed the one that was all highway)
Before:
30.36
30.53
30.83
After Replacing the front 2 tires:
31.34
