Old 02-27-2008, 09:27 PM   #14 (permalink)
diesel_john
MP$
Send a message via MSN to diesel_john
Smile
I just realized, you have a positive displacement pump in your diesel. You can probably make a good guess at fuel consumption based on the throttle position and rpm alone, as long as you leave the smoke screw alone [/quote]
A couple years ago, on the diesel, i mounted a thottle positon sensor on injector pump linkage. so at a given conditions, i can read the resistance change and get a relative number to comparing mods. i test both directions on the same road at 55mph.
