07-26-2009, 01:03 PM
#9 (permalink)
Moderate your Moderation.
Originally Posted by CapriRacer
Ah ........ Mmmmmm ............. Where to start?
The load carrying capacity of a tire is determined by quite a few things - directly: the amount of allowable deflection - which is a function of the size of the air chamber, inflation pressure, and some factors to account for the type of service. Indirectly: the size of the air chamber is a function of the section width and the diameter.
The factors used to account for the type of service can be boiled down to:
The higher the speed, the less the load capacity.
The rougher the road, the less the load capacity.
The more sensitive the service, the less the load capacity. (Meaning if people are involved or a tire failure causes a major problem - like on an airplane.)
In the case of trailer tires, they aren't stronger. They are just allowed a higher load capacity because of the lower speed limitiation and the fact that they don't carry people, and a tire failure on a trailer wouldn't have as large an impact as one on a car.
BTW, a P175/70R13 Standard Load has a rated inflation pressure of 35 psi, while a 4.80-12 Load Range B has a rated inflation pressure of 60 psi. That's quite a difference!
One of the issues with higher inflation pressures is impact resistance. A tire's ability to absorb the energy (Force X distance) of a penetrating object is a function of its spring rate. Lower inflation pressures allow a tire to absorb more energy. While impact type failures are fairly rare, because they completely destroy the integrity of the tire, they need to be avoided if possible.
BTW 4.80-12's are mostly used in light trailer applications - boat and utility trailers - and those usually don't have brakes. Cornering? Well, not so much.
Overall, I could see these type of tires being used on an city type electric vehicle where the top speed is limited by the size of the electric motor. Sort like those golf cart type vehicles - which in fact use these types of tires.
Thanks - That's actually what I was pointing the question toward, something that won't go over 45 even if you try, but something more-so designed to commute through cities or even in suburbia or some of the less sparsely populated country areas... like the 3 miles to the local store around here, on a highway that is frequented by farm equipment. (PA SR14N)
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
