Old 07-27-2009, 03:15 AM   #11 (permalink)
roflwaffle
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Originally Posted by nubbzcummins View Post
It would work like that if you use equal parts of both but this is probly not the case.
Are you sure about that? Lets construct a similar situation, but w/ the same fuel to simplify energy content issues. Lets say my car gets 25mpg. I get a gallon of fuel from Shell, Arco, Exxon, and Ned's family gas station. Then I drive 100 miles. Technically, since I used a little bit of each station's gas, I went 100 miles on Shell, 100 on Arco, etc... And since, like ya mentioned, I was using equal parts, I got 100mpg on Arco, and on Shell, etc...
Example if you use equal parts the mpg avg would be 40mpg but if you use 75% at 20mpg and 25% at 60mpg the avg would drop to 30mpg due to the amount used being weighted more towards the one that yields lower mileage. But hey, 60mpg is not bad in a big truck!
We're using diesel at 60mpg, and a gallon of propane, be it a GGE or GDE of propane, or a gallon in terms of volume, at 20mpg. To go 20 miles, we used 1/3rd of a gallon of diesel, and one gallon of propane. If it's a gallon of gasoline or diesel equivalent propane, then we used ~37-42kWh of propane, plus another 14kWh of diesel, to go 20 miles, which works out to ~51-56kWh for 20 miles that is the equivalent of ~1.21-1.33 gallons of diesel, so over 20 miles we're looking at ~15.1-16.5mpg. If it's a straight up gallon of LPG, then it's ~28kWh of propane, plus 14kWh of diesel, for ~42kWh/1 gallon of diesel, and that's ~20mpg. Either way, it ain't 40mpg or 30mpg. ~15-20mpg is the norm for a conservatively driven pickup. Not to say that diesel pilot ignition of propane or natural gas isn't more efficient, just that it's not 30-40mpg more efficient.
Odds are the person who started that wanted to sell propane injection.
