Propane makes perfect sense if you can get propane for 60% of the price of No.2. Otherwise it is a waste of money.
Propane/nitrous will give you a tremendous short term torque boost. Don't advance your injection timing when using propane or you will grenade the engine.
HHO works only if somebody repealed the Second Law of Thermodynamics.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
