Old 07-31-2009, 11:50 PM   #9 (permalink)
nubbzcummins
THE DODGE - '06 Ram 2500 ST
90 day: 22.64 mpg (US)
The Saturn - '08 Vue XR
90 day: 21.94 mpg (US)
The Odyssey Van - '011 Odyssey EX-L
90 day: 29.1 mpg (US)
Update: Just added a new fuel log with the 33ohm resistor between signal and ground on the map sensor. Idle voltage sensed was 1.18v vs 1.28v normal and max sensed on grades at 55mph cruise is 1.91v vs 2.32v normal. Managed 21.71mpg and 800.3 miles this tank. For my next tank I have it set to where idle voltage sensed from the map sensor signal is 1.1v and max on grades at 55mph cruise is 1.3v. Doing well so far as it seems to be doing slightly better than my last tank. Will have another update in about a week.
