Steel wheels to eventually put on some moon disks for aero.
I don't think its the bolt pattern that's the problem. i believe its the offset or center bore.
I just took a look at that chart, looks like the Saturn wheel that I had them order might fit.
Though I should probably try to find some wheels used from a wrecking yard instead of buying new.
Thanks for your help.
